Aug 13th, 2024, 11:27am
Integrator Design Problem (Read 2022 times)
analog_design
INDIA
Aug 13th, 2012, 10:13pm
I am designing simple integrator. When Reset is going in off state. integration is starting.When Integration is started. There is dip from 2.5 V to 2 V after that integration of injected current is starting.
I did not understant why there is  dip of 0.5 V.
Please, help me to understand phoenomenon. Please, go through an attached simulation waveform.
Warm Regards
View Profile analog_design   IP Logged
A Kumar R
India
Re: Integrator Design Problem
Reply #1 - Aug 14th, 2012, 5:46am
Could you please elaborate the question and the diagrams further..?
Please show the input also..?
thanks
Anil Reddy
Reply #2 - Aug 26th, 2012, 1:03pm
Without more information?
Looks like charge injection from a switch into a small integration capacitance.
