Sep 3rd, 2024, 7:18pm
which BJT (pnp/npn) is better to use in a BGR? (Read 5796 times)
yvkrishna
Aug 14th, 2012, 8:54am
Given a choice to use both npn/pnp bjts  in a cmos process which one is better to use in Bandgap reference design? Assume both of them have same beta (current gain=ic/ib)
As already known having poor beta causes additional voltage drop in base resistance which could finally limit the accuracy of bandgap.  Is it just enough to pick the one which has higher beta?
Area there any other tradeoffs related to inherent curvature of VBE, area, speed etc?
Or are there any better topologies in which only one of them could be employed?
yvkrishna
« Last Edit: Aug 14th, 2012, 10:21am by yvkrishna »
Re: which BJT (pnp/npn) is better to use in a BGR?
Reply #1 - Aug 26th, 2012, 1:01pm
the collector tied PNP is commonly used.
I have used PN junctions and gotten good results if the models are properly defined.
Kevin Aylward
Reply #2 - Jul 14th, 2013, 10:06am
Speed may be an issue in that slower devices may be harder to stabilise in a feedback loop. In a CMOS process I would expect that the npn will be much faster than any pnp. Often the pnp is not a real one. The best bandgaps use bipolars as transistors, not merely as diodes, and use both types throughout. A key issue when Mosfets are used, is the difficulty in trimming to a universal “magic” voltage. If all bipolars are used, all offsets are tuneable  ptats. That is, if the bg is trimed to the magic voltage, it will have the correct square shape temperature curve, irrespective of individual errors. This is important as it allows the band gap to be set with one trim at, say, 27 deg. Unless all Mosfets are relatively, absolutely huge, say 200u/40u, a trim to what should be a magic voltage won’t be. In which case production trimming becomes a nightmare.
Kevin Aylward
tm123
Chicago, IL
Reply #3 - Jul 22nd, 2013, 9:18am
yvkrishna,
If you are using a CMOS process, substrate PNP's are usually available without adding much if any cost to the mask set.  Of course the limitation is that the collector terminal of the transistor must be tied to the substrate.  Lower beta, slower speed etc. are also inherent with substrate pnp's but you should still be able to make a reasonable bandgap reference circuit.  I expect adding NPN transistors in a CMOS process will cost you $$ because of added mask layers.  If I were using a BiCMOS process I would certainly choose NPN transistors.
I would recommend the Gray/Meyer text book as a basic reference, but several books have bandgap reference circuits in CMOS processes.  I have used Brokaw cells and PTAT generators when NPN's are available.
Hope this helps.
Tim
Reply #4 - Aug 2nd, 2013, 6:56pm
this was asked over a year ago...
