Sep 18th, 2026, 9:32pm
Issues in SNR calculation for Delta Sigma ADC (Read 5778 times)
sourav
Aug 30th, 2012, 4:47am
Hi Guys,
I am finding issues in SNR calculation for my Simulink model and the model given in Screier toolbox.A  pdf file is attached with the SNR figures and the model i have used
Specifications for my simulink model:
Amplitude= 0.8
Samples per period= 1170
Sample time= 10^-6
Frequency=2*pi*854.49 Hz
a,g,b,c have been calculated for CIFB model as:
H = synthesizeNTF(2,256,0,2);
[a,g,b,c] = realizeNTF(H,'CIFB')
a =
  0.4721    1.2361
g =
   0
b =
 0.4721    1.2361    1.0000
c =
   1     1
Matlab code for SNR calculation:
OSR = 256;
H = synthesizeNTF(2,OSR,0,2);
N = 8192; fB = ceil(N/(2*OSR));
f=7;
u = 0.8*sin(2*pi*f/N*[0:N-1]);
v = simulateDSM(u,H);
t = 0:1000;
stairs(t, u(t+1),'g');
hold on;
stairs(t,v(t+1),'b');
axis([0 200 -1.2 1.2]);
ylabel('u, v');
spec=fft(v.*ds_hann(N))/(N/4);
%figure
plot(linspace(0,0.5,N/2+1), ...
dbv(spec(1:N/2+1)));
axis([0 0.5 -120 0]);
grid on;
ylabel('dBFS/NBW')
snr=calculateSNR(spec(1:fB),f);
s=sprintf('SNR = %4.1fdB\n',snr)
text(0.25,-90,s);
s=sprintf('NBW=%7.5f',1.5/N);
text(0.25, -110, s);
Problem is that SNR for my model does'nt scale with OSR and also significantly smaller than theoretical one....
All sorts of suggestions are solicited....
Thanks and Regards,
Sourav
nrk1
Re: Issues in SNR calculation for Delta Sigma ADC
Reply #1 - Sep 1st, 2012, 8:53am
You need to look at the signal band in more detail. From the plots, it appears that your model has more junk in the signal band, but impossible to say for sure. You should also do it for lot more than 8192 points(2^16 or more), take the PSD with averaging so that you can discern small differences.
Reply #2 - Oct 6th, 2012, 4:52am
Hi Sourav,
Would you please show the plots in log scale for x-axis? And it is good to attach it as picture?
Yawei
sourav
Reply #3 - Mar 16th, 2013, 11:53am
Hi Guys,
sorry for late response. I have found out the actual problem. Notice the sine wave block in pdf. In matlab simulink there are two options to define a sine wave; one is time based and another is sample based. In early simulations i have tried with the sample based sine wave. But when i select the time based sine wave option in sine block the problem get resolved. I dont know the actual reason but its working. Huh
sourav
