Aug 14th, 2024, 3:21am
DTCXO architecture options (Read 3199 times)
lunren
Asia
Sep 14th, 2012, 8:42am
Hi All,
I am working on a Digital Compensated Crystal Oscillator design for real time 32.768kHz clock (part of the whole project). Now there are two options in terms of architecture:
1) temperature sensor+EEPROM+analog option(change tunable xtal load capacitor bank) to change oscillation frequency
2) temperature sensor+EEPROM+digital option( keep the xtal load capacitor unchanged, but digitally change the time counter to add or remove pulse to speed up or slow down the clock counter)
The problem in 1) is we need big area to put the tunable load capacitor on-chip, however we are area limited (if we have enough area, the frequency compensation precision can be high enough);
The problem in 2) is we are not sure if it works well, especially let's say the counter precision up to +/-3ppm.
I am hoping there are some DTCXO/TCXO expert at here can give some comments.
Lunren
Lunren
Re: DTCXO architecture options
Reply #1 - Sep 15th, 2012, 1:55am
Hi Lunren,
What is your target? +/- 3ppm? Do you need a precise 32.768 kHz clock or 1 Hz signal for real time clock ?
Yawei
lunren
Asia
Reply #2 - Sep 15th, 2012, 7:55am
Hi Yawei,
Target is +/-3ppm. I need a 1Hz for real time clock gen. Any suggestion or experience on this?
Lunren
Lunren
Reply #3 - Sep 16th, 2012, 8:18pm
What are you using as your tuning reference?
Also an uncompensated as is 32K RTC is not accurate enough?
If that does not get it done, consider a digital count adjustment method instead.
Doing all kinds of fancy analog tweaking might be more simply
done by using digital number adjustment.
microe
Reply #4 - Sep 17th, 2012, 2:27pm
Not expert.
Just two cents:
there are some existing products out there in the market. Many companies give lots of information in their datasheet. that tells you which approach is more popular, although may not fit into your application exactly.
lunren
Asia
Reply #5 - Sep 18th, 2012, 11:36pm
Hi loose-electron,
The tuning reference is at room temperature. In our application, uncompensated 32K RTC is not enough. I am just afraid there is some limitation on digital number adjustment since it seems some big companies using analog tuning method instead. I don't know if without any compensation, how good the RTC frequency stability is, let's say +/-100ppm across -25C to 85C?
Lunren
Lunren
