Aug 13th, 2024, 7:23pm
about local LDO design (Read 1860 times)
lhlbluesky_lhl
Sep 15th, 2012, 3:55am
i want to design a local LDO (with internal-chip CL)for pre-regulator for my one sub-module, the loading current is 20uA or so. then, what structure can i use? if i use miller two-stage opamp, can it be OK? and what value of CL should i use? 1pF can be OK? is there any suggestion? and what aspects should i consider in my LDO design?
thanks all.
lhlbluesky_lhl
Re: about local LDO design
Reply #1 - Sep 15th, 2012, 7:13pm
and any advice or ideas?
i need your help.
Reply #2 - Sep 16th, 2012, 8:09pm
Start by researching the topic, and then we can help with the more specific questions that you get from that research.
