Jul 16th, 2024, 11:34pm
Low power transceiver (Read 1651 times)
mixed_signal
Sep 19th, 2012, 8:40am
I am working on a low power transceiver for Wireless Body area network protocol. How do I get the phase noise specs of my PLL from the protocol specs. The protocol specifies the transmitter specs like EIRP, transmit mask etc. and receiver specs like sensitivity , ACPR etc.
Re: Low power transceiver
Reply #1 - Sep 22nd, 2012, 12:17pm
you are using this for up convert mixing correct?
Phase noise of the mix product converts to spectral spreading of the output.
