Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Oct 19
th
, 2024, 5:13pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› opamp feedback confusion
Previous topic
Next topic
opamp feedback confusion (Read 1127 times)
summi
Sep 30
th
, 2012, 1:51am
Dear forum,
I would appreciate if any can comment on the opamp polarity selection in the attached file? For me it make sense, however i haven't seen this kind of sign selection.
Br,
Summi.
IP Logged
aaron_do
Re: opamp feedback confusion
Reply #1 -
Sep 30
th
, 2012, 2:52am
What's wrong with it? Just maintains negative feedback for both loops. I wonder what is the point of this kind of amplifier though?
Aaron
IP Logged
summi
Reply #2 -
Sep 30
th
, 2012, 10:43pm
many thanks to Aaron for the reply. I just want to make sure weather it is correct or not. Many people told me other way around(two op amp sign's are interchanged), Could you please tell is that correct? in my opinion it is not correct...
Br,
IP Logged
aaron_do
Reply #3 -
Oct 1
st
, 2012, 2:59am
I'm sorry, I looked at it wrongly. Your friends are right. The signs should be switched. The second stage is a non-inverting amplifier and the big loop is inverting.
Aaron
IP Logged
summi
Reply #4 -
Oct 1
st
, 2012, 3:18am
Dear Aaron,
second opamp also has -ve feedback, it has two feedbacks +ve through R1,R2 but -Ve through R4 and first opamp.
Point me if any thing wrong..
Br,
Summi.
IP Logged
raja.cedt
Reply #5 -
Oct 1
st
, 2012, 5:01am
Hello summui and Aron,
Your choice is correct, other choice would lead to +ve FB dominate over -ve feedback.
Raj.
IP Logged
Reply #6 -
Oct 1
st
, 2012, 11:09am
If I were you I would be very wary of this circuit and its large signal stability. This issue is that you have two opamps in a tight feedback loop. If the input of this circuit changes abruptly then the first opamp could enter slew rate limiting. During this interval the first opamp will be acting like an integrator and so will exhibit 90 degrees of phase shift. If the second opamp normally contributes the dominant pole, then you will have 180 degrees of phase shift around your loop and you will have created an oscillator.
At the very least, I would run a simulation of this circuit where I apply a large pulse with very rapid transitions to the input with the simulator using its conservative settings to see if the circuit is prone to sustained oscillations.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
