prcken
PRC
Hi I found that the open loop gain of the SC CMFB opamp is sampling frequency dependent, I use PSS+PAC analysis, it drops when sampling frequency increases, same opamp configuration with SC-CMFB, the gain drops to 69dB at fs=5MHz. the DC gain is 75dB when fs=1MHz , with continuous time CMFB is 77dB. any idea? thanks
