Jul 5th, 2025, 6:11pm
MATLAB digit precision (Read 5934 times)
Sx_cut
Dresden, Germany
Oct 03rd, 2012, 5:39am
Greetings
I have been trying to import simulation data from Cadence into MATLAB. I save the simulation data in csv format and imported it into MATLAB, but the import wizard shows truncated values with only 4 digit precision while the original values taken from Cadence have upto 15 digit precision. I have attached a figure for reference. Can i enhance digit precision in MATLAB in import wizard?
Maks
San Jose
Re: MATLAB digit precision
Reply #1 - Oct 3rd, 2012, 6:14pm
Internally, Matlab uses double precision for its data.
By default, it displays only 5 digits.
You can increase the number of displayed digits using "format long e" command.
Check this link, or make a search on "Matlab precision" in Google:
http://homepages.math.uic.edu/~hanson/MATLAB/MATLABformat.html
Sx_cut
Dresden, Germany
Reply #2 - Oct 4th, 2012, 2:15am
Thaks Maks,
"MATLAB does its internal arithmetic in IEEE floating point precision using approximately 16 decimal digits, but the default display is only 5 decimal digits, so do not be too concerned about the digits actually displayed as MATLAB output...."
Ref: http://homepages.math.uic.edu/~hanson/MATLAB/MATLABformat.html
