Jul 17th, 2024, 6:44pm
Clock generator with variable period in Verilog-A (Read 8844 times)
gsensor
Oct 18th, 2012, 7:26am
Hi everyone,
I don't use Verilog-A to often, and I'm simply trying to write a clock generator code in Verilog-A with a variable period that changes at fixed time (tend3 and tend 4). It is also activated by an input enable signal. When en input is higher than 1 V, the clock is generated in the output signal (out), else, the output signal (out) goes to 0V. The out signal (or CLK) has a maximum amplitude of 2V.
Here's my code
`include "constants.vams"
`include "disciplines.vams"
module clk_generator_va(en,clk);
parameter real tt = 0n;	  // output transition time (s)
parameter real t3 = 500n;
parameter real t4 = 1u;
output out;
input en;
voltage out,en;
real Vout,td,tend,tend2, tend3, tend4;
analog begin
    @(initial_step) begin
	    Vout = 0;
	    td =2.5n; //time 0, clk_period = 5ns
	    tend = $abstime + td;//return simulation time + td
	    tend2 = $abstime + td +td;//return simulation time + 2td
	    tend3 = $abstime + t3;//return simulation time + t3
	    tend4 = $abstime + t4;//return simulation time + t4
   @(timer(tend)) begin
     if (V(en) < 1) //Check en condition, if en<1V, Vout = always 0V
	  Vout =0;
     else		 //Else, Vout=2V and a clock is generated at out.
	  Vout = 2;
    @(timer(tend2)) begin
	    tend2 = $abstime + td +td;//return simulation time + td
	    Vout = 0;
    @(timer(tend3)) begin
	    td = 5n;// clk_period change to 10ns.
    @(timer(tend4)) begin
	    td = 10n;// clk_period change to 20ns.
    V(out) <+ transition(Vout, td, tt);
I get a response varying depending on the transient simulation time I set. When I simulate for 1.1 us it works fine, with a VDC source attached to en..(see picture 1). Although, if I simulate for 20 us, I get an output signal with a maximum amplitude of 1V (see picture 2).
When I vary en from 0 to 2.5V every 4 us using vpulse source attached to en, I get an output signal of 200 mV (see picture 3).
It must be a parameter to set for the simulator, but which one ?
I use Spectre simulator in Cadence version 5.1.4 -USR6
How do I fix this ?
gsensor.
gsensor
Re: Clock generator with variable period in Verilog-A
Reply #1 - Oct 18th, 2012, 7:26am
Picture 1:
With en = 2.5 V
gsensor
Reply #2 - Oct 18th, 2012, 7:40am
Picture 2:
With en = 2.5V and total simulation time is 20 us (althougth only the first 3 us is shown here to allow a better visualisation of the signal..)
gsensor
Reply #3 - Oct 18th, 2012, 7:41am
Picture 3:
With en varied every 4 us, using a vpulse source attached to input en.
Reply #4 - Oct 18th, 2012, 10:00am
Your asking for trouble by setting the transition time of the transition filter to 0. I recommend you start by giving it a reasonable value. I also think the logic behind your oscillator is not correct. I recommend that you start from a working oscillator and hack it up until you get what you want. Try looking at the Verilog-AMS page on this site. In particular, you can find fixed-frequency oscillators in http://www.designers-guide.org/VerilogAMS/functional-blocks/osc/osc.va.
boe
Reply #5 - Oct 19th, 2012, 11:52am
Gsensor,
Two additional things: a) 5.1.41USR6 for the spectre is quite old.
b) the delay of the transition filter seems suspect to me.
- B O E
