Jul 17th, 2024, 6:28pm
usage of noise_table (Read 1726 times)
Richardsim
Oct 26th, 2012, 4:04am
I am trying to use the noise_table noise function using the module included below. The ac simulation result, connecting the tnoisesourcemin terminal to gnd and the tnoisesourceplus terminal to a simple beam stiffness model, is a zero displacement magnitude output for all frequencies. I am working in Virtuoso 6.1.4.
Does anyone have any suggestions what I'm doing wrong?
Many thanks in advance,
Richard
//Verilog-AMS HDL for .....
`include "constants.vams"
`include "disciplines.vams"
module NoiseTable (tnoisesourceplus,tnoisesourcemin);
   inout tnoisesourceplus,tnoisesourcemin;
   kinematic tnoisesourceplus,tnoisesourcemin;
// mechanical properties
//    parameter real mag = 0.000001;  // N/m
// noise source amplitude information
parameter real f1 = 0.001; //Hz
parameter real A1 = 0.000001; //m
parameter real f2 = 0.01; //Hz
parameter real A2 = 0.000001; //m
parameter real f3 = 0.1; //Hz
parameter real A3 = 0.000001; //m
parameter real f4 = 1; //Hz
parameter real A4 = 0.0000001; //m
parameter real f5 = 100; //Hz
parameter real A5 = 0.000000001; //m
analog begin
Pos(tnoisesourceplus,tnoisesourcemin) <+ noise_table({f1,A1, f2,A2, f3,A3,f4,A4, f5,A5}, "surface");
Re: usage of noise_table
Reply #1 - Oct 29th, 2012, 5:57am
What you posted looks OK to me; could be the beam stiffness model.  I have three suggestions:
1) try the NoiseTable module by itself -- just leave the tnoisesourceplus floating, since you're setting the "potential" (Pos) for the kinematic discipline, there shouldn't be any singular matrix problems
2) try using a ' before the { in the call; I think the latest LRM requires a single-quote ' before array literals
3) try using numbers, rather than parameters, in the array (just to see if that's the problem -- I understand you want to have parameters)
