Hi everyone,
I don't use Verilog-A to often, and I'm simply trying to write a clock generator code in Verilog-A with a variable period that changes at fixed time (tend3 and tend 4). It is also activated by an input enable signal. When en input is higher than 1 V, the clock is generated in the output signal (out), else, the output signal (out) goes to 0V. The out signal (or CLK) has a maximum amplitude of 2V.
Here's my code
Code:`include "constants.vams"
`include "disciplines.vams"
module clk_generator_va(en,clk);
parameter real tt = 0n; // output transition time (s)
parameter real t3 = 500n;
parameter real t4 = 1u;
output out;
input en;
voltage out,en;
real Vout,td,tend,tend2, tend3, tend4;
analog begin
@(initial_step) begin
Vout = 0;
td =2.5n; //time 0, clk_period = 5ns
tend = $abstime + td;//return simulation time + td
tend2 = $abstime + td +td;//return simulation time + 2td
tend3 = $abstime + t3;//return simulation time + t3
tend4 = $abstime + t4;//return simulation time + t4
@(timer(tend)) begin
if (V(en) < 1) //Check en condition, if en<1V, Vout = always 0V
Vout =0;
else //Else, Vout=2V and a clock is generated at out.
Vout = 2;
@(timer(tend2)) begin
tend2 = $abstime + td +td;//return simulation time + td
Vout = 0;
@(timer(tend3)) begin
td = 5n;// clk_period change to 10ns.
@(timer(tend4)) begin
td = 10n;// clk_period change to 20ns.
V(out) <+ transition(Vout, td, tt);
I get a response varying depending on the transient simulation time I set. When I simulate for 1.1 us it works fine, with a VDC source attached to en..(see picture 1). Although, if I simulate for 20 us, I get an output signal with a maximum amplitude of 1V (see picture 2).
When I vary en from 0 to 2.5V every 4 us using vpulse source attached to en, I get an output signal of 200 mV (see picture 3).
It must be a parameter to set for the simulator, but which one ?
I use Spectre simulator in Cadence version 5.1.4 -USR6
How do I fix this ?
gsensor.
