Richardsim
I am trying to use the noise_table noise function using the module included below. The ac simulation result, connecting the tnoisesourcemin terminal to gnd and the tnoisesourceplus terminal to a simple beam stiffness model, is a zero displacement magnitude output for all frequencies. I am working in Virtuoso 6.1.4. Does anyone have any suggestions what I'm doing wrong?
Many thanks in advance, Richard
//Verilog-AMS HDL for ..... `include "constants.vams" `include "disciplines.vams"
module NoiseTable (tnoisesourceplus,tnoisesourcemin);
inout tnoisesourceplus,tnoisesourcemin; kinematic tnoisesourceplus,tnoisesourcemin;
// mechanical properties // parameter real mag = 0.000001; // N/m
// noise source amplitude information parameter real f1 = 0.001; //Hz parameter real A1 = 0.000001; //m parameter real f2 = 0.01; //Hz parameter real A2 = 0.000001; //m parameter real f3 = 0.1; //Hz parameter real A3 = 0.000001; //m parameter real f4 = 1; //Hz parameter real A4 = 0.0000001; //m parameter real f5 = 100; //Hz parameter real A5 = 0.000000001; //m
analog begin
Pos(tnoisesourceplus,tnoisesourcemin) <+ noise_table({f1,A1, f2,A2, f3,A3,f4,A4, f5,A5}, "surface");
