Jul 16th, 2024, 11:13pm
Matching to Internal Antenna (Read 1531 times)
aaron_do
Oct 29th, 2012, 1:09am
I have checked that for a mobile phone internal antenna, a reasonably good VSWR seems to be around 3:1. Since the PA is normally designed to drive a 50-ohm load, does this mean that most handsets these days feature a broadband match between the cellular switch and the antenna? If so, how is it normally implemented? LC matching?
From what I've been reading, the antenna's performance is very sensitive to its surrounding environment, so it seems that the manufacturers need to first develop the floor plan for the RF front end and then design the matching based on the best performance. Does that sound right?
thanks,
Aaron
BTW, I realize I probably shouldn't be using the word matching since it isn't really impedance matching...
« Last Edit: Oct 29th, 2012, 6:52am by aaron_do »
Re: Matching to Internal Antenna
Reply #1 - Oct 31st, 2012, 9:33pm
There is usually an LC network between the antenna and the RF PA.
Also the polar plots for the antenna need to be re-run in the phone environment because component placement in the phone does affect the radiation patterns.
There are many vendors of ceramic and (and other) substrate based antennas out there.
Take a look at their application notes for ideas on LC networks to the PA.
