Oct 19th, 2024, 1:37pm
Pages: 1 2
CMFB of OTA (Read 9719 times)
urian
CMFB of OTA
Oct 30th, 2012, 6:39am
Hi,there.
Recently I am designing a OTA used in a front-end S/H for pipeline ADC. The OTA circuit is shown below,  and I dont know how exactly the CMFB is working. The VDD is 3V and CM voltage of input and output are both 1.4v, while using SC CMFB. When simulating, I find that the output CM voltage is affected by other transistors parameters especially the M3 and M4 even with CMFB is working! In other words, the output CM voltage is hard to adjust to the desired value 1.4v, and is susceptible by other transistors with CMFB. I dont know why the CM voltage can not be controlled by CMFB. The DC gain of differential is about 60 dB and the first stage has a gain about 2, so I think the CMFB loop gain is large enough to force deep feedback.
urian
AnalogDE
Re: CMFB of OTA
Reply #1 - Oct 30th, 2012, 5:06pm
What does your CMFB circuit look like?
urian
Re: CMFB of OTA
Reply #2 - Oct 30th, 2012, 9:23pm
AnalogDE wrote on Oct 30th, 2012, 5:06pm:
Hi,AnalogDE, the CMFB is a traditional SC CMFB.
Dan Clement
Salt Lake City, Utah, USA
Re: CMFB of OTA
Reply #3 - Oct 31st, 2012, 4:26am
Shouldn't m3 and m4 be pmos?
urian
Re: CMFB of OTA
Reply #4 - Oct 31st, 2012, 7:34am
Dan Clement wrote on Oct 31st, 2012, 4:26am:
Hi,It's NMOS for sure.
Dan Clement
Re: CMFB of OTA
Reply #5 - Oct 31st, 2012, 7:40pm
I've never seen this topology before. From what I see I don't think there is a chance for this circuit to act as an amplifier.
Can you explain how it is supposed to work?  It doesn't make sense to me.
urian
Re: CMFB of OTA
Reply #6 - Oct 31st, 2012, 9:11pm
Hi,it's from the JSSC paper " A 10b 20M 35mW Pipeline A/D Converter" by Cho,Mar,1995
Dan Clement
Re: CMFB of OTA
Reply #7 - Nov 1st, 2012, 5:40am
I will have to look into that paper.
After a good night of sleep I can now see it as an amp. The gain of the first stage will be quite low.
The signal swing of the first stage will be severely limited by the cmfb as you can't pull the drains of the input transistors any higher than the cmfb node minusvavthreshold voltage.
You are probably having a startup issue where the input transistors are being clamped by the cmfb source followers or you are having a swing issue and losing gain.
You will need to level shift the cmfb to a high enough voltage to avoid this.
urian
Re: CMFB of OTA
Reply #8 - Nov 1st, 2012, 9:26pm
Yes, the gain of first stage is low, between 1-2, the drain of input transistor is around 800mv with the bias, but the output will change largely with SF transistors parameters.
Lex
Eindhoven, Holland
Re: CMFB of OTA
Reply #9 - Nov 5th, 2012, 4:25am
Are the problems gone with a higher common mode voltage? Then I guess you know the answer to your problems.
boe
Re: CMFB of OTA
Reply #10 - Nov 5th, 2012, 4:30am
Lex wrote on Nov 5th, 2012, 4:25am:
I"d try lower (input) common mode voltage...
- B O E
urian
Re: CMFB of OTA
Reply #11 - Nov 5th, 2012, 7:38am
Do you mean the output CM voltage? If so, I am afraid I cant afford this as the CM voltage is determined by BIAS and it tends to be smaller. Actually, I find that with this cmfb, the DC OP is very important to guarantee that the CMFB loop has enough gain.
boe
Re: CMFB of OTA
Reply #12 - Nov 5th, 2012, 11:08am
urian wrote on Nov 5th, 2012, 7:38am:
I believe Lex meant changing it to test the circuit behavior.
Quote:
Actually, I find that with this cmfb, the DC OP is very important ...
As I'd expect given the topology.
Quote:
... to guarantee that the CMFB loop has enough gain.
So what is your question?
- B O E
Lex
Eindhoven, Holland
Re: CMFB of OTA
Reply #13 - Nov 6th, 2012, 12:03am
boe wrote on Nov 5th, 2012, 4:30am:
- B O E
I think we're on the same page. Wink
urian
Re: CMFB of OTA
Reply #14 - Nov 6th, 2012, 2:19am
Sorry I made a mistake.When I re-check the circuit, I find that it is because the DC OP of output CM voltage will change largely with SF W/L, and this will put great pressure on CMFB.
Pages: 1 2
