Jul 17th, 2024, 3:32am
berkeley analog fast spice (Read 4395 times)
DSRune
Nov 02nd, 2012, 2:18am
What makes this simulator so fast compared to spectre and other simulators?
bernd
Munich/Germany
Re: berkeley analog fast spice
Reply #1 - Nov 2nd, 2012, 3:12am
Here are some links which may give you a glue about how these
"Fast-Spice" or so called "3rd generation Spice" simulators work
compared to "traditional Spice" based circuit Simulators.
http://rd.springer.com/chapter/10.1007%2F978-94-007-0149-6_2
http://rd.springer.com/chapter/10.1007%2F978-94-007-0149-6_1
http://w2.cadence.com/whitepapers/5084_AccelCircuitWP_FNL.pdf
http://www.allabouteda.com/second-generation-circuit-simulation-fast-spice/
By the way "Berkeley Analog Fast Spice" is not the only simulator in the market
which has this techniques. Mostly all dominant EDA vendors have a derivate of
their main stream "Spice" based circuit simulator which is a "3rd generation
Spice" simulator.
* bernd
Just another lonesome cad guy
Frank Wiedmann
Munich, Germany
Reply #2 - Nov 2nd, 2012, 5:11am
DSRune wrote on Nov 2nd, 2012, 2:18am:
See http://www.berkeley-da.com/prod/tech_01.htm, especially the last paragraph. Cadence has taken a similar approach with their new APS simulator, which is also much faster than their old Spectre simulator.
Bernd: BDA AFS is not a FastSPICE simulator like UltraSim or the new XPS from Cadence (which BDA calls "Digital FastSPICE").
