lhlbluesky_lhl
in the following picture, the schematic is a part of an ir receiver, here is a twin-t notch filter and a non-inverting amplifier. in the notch filter, R is programmable (s[2:0]), and switch here is nmos transistor (having body effect), when simulation(assuming s[2:0]=100), in some corner, the leakage current of s[2] is 25nA also, causing a voltage drop of 10mv between VI and non-inverting input of opamp of notch filter; while in other corner, the leakage current of s[2] is only 20pA (what i expected). i checked the operating point, the leakage current of s[2] is not substrate leakage, it is channel leakage between source and drain. and if i disconnect the output of notch filter with input of the non-inverting amplifier (VR is reference voltage from bandgap), the above leakage current of s[2] can be 20pA~50pA for all corners, as i expected. this is very strange. i wonder why. how is the channel leakage current of s[2] generated? or is it gate leakage of input pair of notch filter opamp? please give me some suggestions, thanks all.
