Jul 5th, 2025, 2:08pm
low BW pll loop filter (Read 6942 times)
raja.cedt
Dec 03rd, 2012, 10:25am
While reading a doc from ee times, i came to know that there are few applications which require PLL bw around 10Hz, i wounder how people manage that kind of filters. The only one idea came to my mind when i read this nA charge pump current  and very low resistance. I would like to hear some implementable solution.
Raj.
smlogan
Boston, MA
Re: low BW pll loop filter
Reply #1 - Apr 11th, 2013, 9:35am
Hi Raj,
Loop bandwidths of this magnitude are usually bulkwave quartz based. In other words, the Kvco is very low (often much less than 100 ppm/V). They are used for highly stable clocks often referred to as Stratum III or better. In some cases, the frequency varying element is non-crystalline, but also possesses an extremely low Kvco.
I hope this helps!
Shawn
Shawn
raja.cedt
Reply #2 - Apr 11th, 2013, 12:39pm
hello thanks for the reply. Do you mean filter might be a SAW based and VCO based on crystal oscillator??
raj.
Lex
Eindhoven, Holland
Reply #3 - Apr 12th, 2013, 2:43am
Go digital?
smlogan
Boston, MA
Reply #4 - Apr 17th, 2013, 2:23pm
Hi Raj,
Sorry for the delayed response...
Yes. A bulkwave quartz based oscillator (VCXO) will have a lower Kvco in general than a quartz surface acoustic wave based oscillator (VCSO). Hence, the latter is most often used in low bandwidth PLL.
Shawn
Shawn
