Jul 28th, 2024, 3:11am
MAx decap value (Read 3017 times)
summi
MAx decap value
Dec 11th, 2012, 3:02am
Dear forum,
Can any one tell me how to How deside decap for chip, i know it is very difficult to predict, but how to come up with a rough number. Recently i have joined IC design job, there i have seen people are filling all gaps with decaps while taping out the chip. So i like to know what limit the max value of the cap.
Br,
Summi.
raja.cedt
Re: MAx decap value
Reply #1 - Dec 11th, 2012, 4:24pm
It depends on many factors, some time(many times) decap helps to reduce the impact of switching noise. May be resonance frequency(which is larger than signal frequency) between bond wire inductance and decap  will place the upper limit. For flip chip there is no this kind of limit.
Some experienced people will find dynamic power of the chip and estimate Ceffective from Cv^2f formula.
Raj.
Re: MAx decap value
Reply #2 - Feb 8th, 2013, 6:51pm
Inside the chip capacitinace should be sufficient for power decoupling at frequencies where interconnect inductance to the outside world does not allow you to do it with external capacitors.
Go figure out the inductance of your leadframe and bond wires.
Erez_Sarig
Re: MAx decap value
Reply #3 - Feb 8th, 2013, 11:11pm
Answer is simple:
As no one design the die size based on Decap values needed + the Decap are needed to reject any ripple on supplies, the value of Decap needed is:
As much as you can where ever you can. But note to have also Taps to GND as they are improtant also.
Later you can simulate Fullchip with package model and see effect just note that PCB trace most of the time have higher inductance as minimum lenght of pcb trace is ~2mm which is ~2nH-5nH.
Erez Sarig
