Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Oct 19
th
, 2024, 1:34pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› how the low frequency noise generated?
Previous topic
Next topic
how the low frequency noise generated? (Read 522 times)
lhlbluesky_lhl
Dec 13
th
, 2012, 5:20am
when testing my power ic, i have found a low frequency noise at clock output (noise at
1hz or lower
), but there is no circuit module working at so low frequency. and can it be flicker noise (opamp or comparator)?
thanks.
IP Logged
raja.cedt
Re: how the low frequency noise generated?
Reply #1 -
Dec 13
th
, 2012, 7:24am
what is your circuit, i guess main source for this component is inter-modulation. If it is because of flicker noise, you should see low band spectrum rather a spur at 1HZ. Describe more abut the problem.
Raj.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
