Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 16
th
, 2024, 11:13pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› PA necessary for -10dBm TX output power?
Previous topic
Next topic
PA necessary for -10dBm TX output power? (Read 2061 times)
mixed_signal
Dec 23
rd
, 2012, 7:15pm
I am designing a transmitter with o/p power of -10dBm. This translates to a peak to peak voltage 200mV. Is there any necessity of power amplifier if the O/P is available from a LC oscillator capable of generating such Vpp=200mV
IP Logged
vp1953
Re: PA necessary for -10dBm TX output power?
Reply #1 -
Dec 24
th
, 2012, 2:54pm
The output is going to a 50 ohm trace? then you need a buffer otherwise it might load your VCO heavily and stop it from working.
IP Logged
mixed_signal
Reply #2 -
Dec 26
th
, 2012, 11:07am
Thank you vp1953! The load is 50ohms
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
