Jul 17th, 2024, 1:30am
Digital sizing for RF: PFD (Read 936 times)
mixed_signal
Dec 30th, 2012, 10:41pm
I am designing a 2.4Ghz integer N PLL with 1Mhz reference. While sizing inverters for RF is there any special  considerations in sizing inverters/gates , I mean PMOS to NMOS ratio etc.
I have sized for highest speed i.e. beta=2. Although power consumption is also a concern for me
raja.cedt
Re: Digital sizing for RF: PFD
Reply #1 - Dec 31st, 2012, 1:02am
hello,
though it is RF application, pfd will work as digital block. Make sure that Inverter has very low rise time (it may impact dead zone, i am not so sure). But beta around 2 might cause problems, but i have idea abut you technology so be care full while choosing beta, in earlier my design beta around 3.
Raj.
mixed_signal
Reply #2 - Dec 31st, 2012, 10:15am
Hi raja.cedt,
I am using IBM 130nm tech. So, how beta should be selected
1) symmetric swing i.e. equal rise and fall time i.e beta=3.5 etc. OR
2) Highest speed beta=2
Thanks!
raja.cedt
Reply #3 - Dec 31st, 2012, 1:00pm
use 3.5.
What do you mean by high speed beta?
Raj.
mixed_signal
Reply #4 - Dec 31st, 2012, 5:58pm
High speed beta means that the ratio for which sum of tpLH + tpHL is minimum.
To get an intuitive appeal: If you design a ring oscillator with inverters sized for minimum delay then the oscillator will have the highest frequency.
Since in my RF design both speed and power is a concern, I was wondering if there is some optimal sizing
