Aug 15th, 2024, 7:43am
Clarification needed using "port" source in Virtuoso (Read 778 times)
Sharath Raju
Dec 31st, 2012, 5:36pm
I understand that the internal resistance of the "port" source is 50 ohm by default. If the peak voltage amplitude is set to 1 V and the termination is set to 50 ohm, shouldn't the peak voltage across the 50 ohm load be 0.5 V due to a voltage division between the 50 ohm impedance of the source and the load ?
To do a sanity check, I replaced the port source with a "vsin" source in series with an external 50 ohm resistance. The source voltage divides in half as expected.
Attached is the schematic and simulation result. Note that /L and /Lprime are the load voltage waveforms with the port and vsin sources respectively.
Sharath
Re: Clarification needed using "port" source in Virtuoso
Reply #1 - Dec 31st, 2012, 6:29pm
The Spectre port source is modeled after a signal generator. In a signal generator, you specify the level you want with the implied assumption that the generator is properly terminated. So if you specify 1V, you get 1V but only if the source is terminated in its reference impedance. If you do not terminate it (you leave it open), you get 2V.
Sharath Raju
Reply #2 - Dec 31st, 2012, 6:37pm
Thanks Ken..changed the load to 100 Mega ohm and quickly saw that the voltage jumped to 2V amplitude.
