Jul 17th, 2024, 1:39am
pll vco control voltage in simulink (Read 10210 times)
mixed_signal
Jan 07th, 2013, 6:07pm
i simulated  my pll using simulink n time domain and ended up with peculiar control voltage even with 60 deg/75deg PM.
Fig 1 shows the output of loop filter. Fig. 2 shows output after VDD saturation. I want my vco control voltage to slightly rise from 0 at t=0 and settle as if critically damped.
Is it due very small ref frequency and high N=2500
fref=400khz  fout=1Ghz  N=2500
mixed_signal
Re: pll vco control voltage in simulink
Reply #1 - Jan 7th, 2013, 6:09pm
fig1
mixed_signal
Reply #2 - Jan 7th, 2013, 6:10pm
fig2
raja.cedt
Reply #3 - Jan 10th, 2013, 4:40am
There is some thing went wrong in calculations or loop Bandwidth higher than Gadner limit  (Fref/10). Show me loop parameters like Icp, Kvco and filter element.
Raj.
mixed_signal
Reply #4 - Jan 15th, 2013, 5:03pm
Hi Raja! Thanks for the favour!
I have the new  specs as follows but I still get almost the same response:
fout=800Mhz
fref=333.3khz
loop bw=33.3khz
Kvco=20mhz/volt
Icp=50uA
C1=2.5pF
C2=32.9pF
R2=541k
BackerShu
Reply #5 - Jan 15th, 2013, 9:19pm
Hello mixed_signal,
How do you know the PM in your real model? (Not from the calculation.)
Did you check the actual loop delay?
raja.cedt
Reply #6 - Jan 16th, 2013, 2:08am
@Mixed signal,
Your Filter resistance is too high, with this you can't charge loop filter, Voltage drop across that is around 10V. So please reduce this resister value to few kilo ohms by adjusting Icp. And also please recalculate gardner  limit by using attached doc. Bw is exactly Fref/10, if you dont have any problem with settling go even below.
@BackerShu,
here divider delay and some other components response time doesn't matter much. Acceptable loop delay without effecting time domain response is .367/(loopBW) is around 2usec in the present case. I don't think getting 2usec delay is common.
mixed_signal
Reply #7 - Jan 16th, 2013, 8:16pm
Hi raja.cedt,
I cant play with current since I have low power constraint.
current is inversly prop with R so to reduce R from 500k to 50k I have to increase current to 500uA which is not possible.
Hi backer,
I am talking abt PM from calculation
BackerShu
Reply #8 - Jan 16th, 2013, 9:03pm
mixed_signal wrote on Jan 16th, 2013, 8:16pm:
If you have to keep the product of Icp*R constant, the ripple in control voltage is really big even if the PLL can reach steady state. I think that's what Raja worried about.
If the bandwidth is fixed, you need to think whether the Kvco you have in the simulation is reasonable or not.
In actual model it might be smaller. This might not be the reason, as Raja mentioned, there is some tolerance for the loop delay. But you can check to rule this out.
raja.cedt
Reply #9 - Jan 17th, 2013, 12:07am
Then you have only one option, redesign VCO. Looks like you have very small Kvco, with generic vco architectures (mainly ring VCO) you could get Kvco min 1Ghz/V. Try this.
If you can't do this then go for dual loop pll(which is having many degree of freedoms) rather conventional loop filter
raj.
mixed_signal
Reply #10 - Jan 26th, 2013, 9:59am
1. I have attached transient response of the control voltage of my PLL in Cadence. This is NOT behavioral reponse.
2. From t=0 to 100us it is the startup time. No frequency step provided
3. At t=170us a frequency step of 40MHz (max size for the pll) is provided and resulting transient response is shown.
The startup response saturates to VDD and then settles. Is this a problem?
Is the  freq step response OK for phase margin of 60 deg.
raja.cedt
Reply #11 - Jan 26th, 2013, 3:51pm
Looks like some thing seriously went wrong in the filter design, that's why some weird start-up, it is dangerous some times just because vctl is saturating and may turn of charge pump. But frequency settling looks okay, though there is some ringing (some part is cycle slipping). Did you modified your charge-pump current (as i suggested earlier), though you don't have power margin just try that (some how reduce the BW) and see the response.  Since you have 33.33khz BW, your loop should settle in 4*tau, which is around 120us but your settling looks pretty faster than this.
Even if you have any problem with settling, due to less Phase margin magnitude response might have few db peaking which amplifies your jitter, so it all depends on which kind application you are targeting.
BackerShu
Reply #12 - Jan 27th, 2013, 11:25am
Hello mixed_signal,
Actually, I think this might not be a big issue at the initial settling. It may be just related to some initial phase condition and frequency offset when the PLL starts.
Can you try to change the initial phase of reference clock, and run the system again. I think you will get different behaviors for initial settling.
