What I meant by "debug your Monte-Carlo setup" was that you would create a netlist, using your best understanding of the documentation, and we would help you figure out if you misunderstood.
From the documentation, you should be able to set up a netlist with some statistics blocks, use the parameters in those stat blocks to set the parameter P of your Verilog-A model, and run the simulation. The only trick I can see you might have trouble with is making sure the netlist contains a parameter assignment for the Verilog-A module:
X1 (a b) my_va_module
isn't good enough, you need
X1 (a b) my_va_module P=value
so that you can pass the statistically-determined value into the module.
