Aug 19th, 2024, 1:27am
about twin-t filter parameter calculation (Read 3193 times)
lhlbluesky_lhl
Jan 19th, 2013, 10:37pm
below is the transfer function of twin-t filter. in actual design, it can also be used for bandpass filter if connected between negative input and output of opamp. now, the twin-t network is a three order system, so, how to get the expression of center frequency f0 and quality factor Q? for two order system, we use 's^2+(2*pi*f0/Q)*s+(2*pi*f0)^2' to calculate f0 and Q, but for the three order system, how to calculate the parameter f0 and Q?
thanks all.
raja.cedt
Re: about twin-t filter parameter calculation
Reply #1 - Jan 19th, 2013, 10:56pm
hello,
this is not a Band-pass Filter(at s=0 and s=inf gain=1) transfer function..
buddypoor
Bremen, Germany
Reply #2 - Jan 20th, 2013, 1:56am
raja.cedt wrote on Jan 19th, 2013, 10:56pm:
hello,
It is.
Ihlbluesky spoke about a twin-T section in the feedback path of an opamp.
If you choose C3=C1+C2  and at the same time R3=R1||R2 you have a pole-zero pair that cancels each other.
Thus, there is a reduction in order from n=3 to n=2.
Therefore, the 2nd order denominator allows to calculate the Q and wp expressions.
lhlbluesky_lhl
Reply #3 - Jan 20th, 2013, 4:02am
but if the relationship C1=C2+C3 and R3=R1||R2 is not satisfied (there is mismatch), such as R1=R2=2*R3 and C2=C3=a*C1(a is not 1/2), so, how to get the expression of f0 and Q? or is there some simple expression here?
