Satya,
Assuming you have access to Virtuoso, IC61x, in the ahdlLib are example components to measure INL and DNL of a data converter. The examples are for 8 bit data converters, you will need to change the variables for your designs and update the pins.
I am perplexed by your request for a delay measurement. While delay can be measured for data converter, performance is usually unrelated to data converter delay. You might find it more useful to perform a parametric sweep of the clock frequency and measure the data converter parameters: THD, SFDR, SNDR, ... and decide based on the performance across frequency what the maximum performance is. All these functions are available in the IC615 version of ViVA when using the spectrum function.
