Frank Wiedmann
In the pnoise PM jitter analysis of SpectreRF, noise from higher frequencies is folded down into the range between zero and half the pss fundamental through the sampling operation of this analysis type. If you use a larger frequency range, you will count the corresponding noise more than once and get a wrong result.
