Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 15
th
, 2024, 7:53pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› biasing of PA
Previous topic
Next topic
biasing of PA (Read 3205 times)
mixed_signal
biasing of PA
Feb 09
th
, 2013, 8:12pm
What is the best way to generate bias VB1, VB2, VB3?
IP Logged
rfidea
Europe
Re: biasing of PA
Reply #1 -
Feb 10
th
, 2013, 5:21am
My first thought was to use current mirrors. For example, use a diode connected reference transistor to bias nodes V1 and V3. The scale the nmos devices to get wanted current. The V2 can be biased by a CMFB loop sensing the dc voltage of drain voltage of the pmos transistor.
One question about biasing the output stage although. If the current is high, maybe a mismatch of a current source can be severe and the current will not be what you want. Maybe the output current should be sensed by a small resistor to ground or vdd and then using feedback. Of course a rail-to-rail amplifier is needed but those can be designed.
Some ideas... Maybe others has other ideas
IP Logged
Erez_Sarig
Re: biasing of PA
Reply #2 -
Feb 10
th
, 2013, 7:11am
Enjoy...
IP Logged
mixed_signal
Re: biasing of PA
Reply #3 -
Feb 10
th
, 2013, 11:18am
Thank you rfidea and Erez_Sarig!
Erez_Sarig:
I cant bias first stage using that. It consumes more power even as class AB. I have to independently bias NMOS & PMOS to be power efficient and operate as class AB
IP Logged
Erez_Sarig
Re: biasing of PA
Reply #4 -
Feb 10
th
, 2013, 11:37pm
Enjoy2...
IP Logged
aaron_do
Re: biasing of PA
Reply #5 -
Feb 12
th
, 2013, 6:58pm
I agree with Erez_Sarig's use of feedback to bias the first stage, but if you want to maximize the output swing of the first stage, you may want to compare the output DC voltage with VDD/2 using a feedback amplifier.
regards,
Aaron
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
