Jul 28th, 2024, 1:13am
Noise in SAR ADC (Read 4512 times)
SATurn
Noise in SAR ADC
Feb 10th, 2013, 6:01am
I was wondering how one could estimate the noise in the cap based dac ? Suppose you have an 8-b SAR ADC which means you need 9 clock cycles to accomplish the conversion. The first one is to sample the input voltage and the rest are for step by step conversion (binary search). So in total, one can count that 9 times the process of sampling or charge sharing will happen.
So now my question is that how the noise of this DAC depends on:
(a) unit cap size
(b) number of cap-based DAC bits or the number of clock cycles for conversion
Armin
dcic
Re: Noise in SAR ADC
Reply #1 - Feb 20th, 2013, 9:08pm
To estimate the noise sampled during the sampling period, one typically regards the DAC as a simple lump cap in series with a sampling switch.  In you case, it will be whatever the size of cap that sufficiently minimize thermal noise for the 8bit ADC, given the full-scale input.  Once the sampling is done, DAC switching during conversion does not contribute to further thermal noise increasing.
Number of conversion cycles will depend on whether redundancy is implemented; if not, 8bit SAR takes 1cycle of sample + 8 cycles of conversion.
Vladislav D
The Netherlands
Reply #2 - Feb 23rd, 2013, 2:45am
dcic wrote on Feb 20th, 2013, 9:08pm:
Not correct. Switching elements in the DAC introduce noise. Voltage switches in a charge redistribution DAC have finite ON-resistance, which essentially generates thermal noise.
There are many possibilities here. It depends.
