Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 17
th
, 2024, 3:38pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› How to determine the input value for 1st-order low pass OTA-C filter??
Previous topic
Next topic
How to determine the input value for 1st-order low pass OTA-C filter?? (Read 832 times)
Jlim
Feb 23
rd
, 2013, 7:08pm
hello,
How to determine the input value for ibias and Vin to generate the correct AC response???urgent!!!
Hope someone can help me~~~
IP Logged
buddypoor
Bremen, Germany
Re: How to determine the input value for 1st-order low pass OTA-C filter??
Reply #1 -
Feb 24
th
, 2013, 2:48am
Jlim, I don`t understand your question.
The circuit was designed by YOU, right?
In this case, only you know about the chosen bias points and the necessary bias input voltages.
Or do you expect that we are simulating your circuit?
IP Logged
Jlim
Reply #2 -
Feb 24
th
, 2013, 9:24pm
Because i have try a lot of value for Ibias and Vin input~~but i still cnt get the correct general AC response for low pass filter~~
Can someone help me try to simulate this circuit and what value i should put???
IP Logged
Horror Vacui
Dresden, Germany
Reply #3 -
Feb 25
th
, 2013, 6:36am
If you don't get a meaningful AC response, then probably your operation point is incorrect. Check voltages and currents in the devices! Check that all transistors are in saturation!
IP Logged
Lex
Eindhoven, Holland
Reply #4 -
Feb 25
th
, 2013, 8:27am
Your ibias is not flowing into a current mirror... so the gate of NM3 and NM2 is floating.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
