Jul 17th, 2024, 5:45pm
Corner (Read 2140 times)
DDC
Corner
Mar 01st, 2013, 1:35am
could somebody describe me, why is high temperature, low Vdd and fast/fast for MOS often the worst case corner ? Thanks for response.
Horror Vacui
Dresden, Germany
Re: Corner
Reply #1 - Mar 1st, 2013, 1:58am
It is not wise to state something like that. The circuit has to be known before deciding the worst case corner. Also a circuit has many worst case corners. It depends on what performance metric are you focusing to.
Re: Corner
Reply #2 - Mar 3rd, 2013, 1:28am
I agree with tzg6sa. It's not easy to say which corner is the worst by rule of thumb. That depends on your circuit and what do you pursue?
Yawei
raja.cedt
Re: Corner
Reply #3 - Mar 3rd, 2013, 2:34am
hello,
as every one pointed out it depends on bias and more imp is parameters of imp.
1.low vdd, slow nmos and pmos, low temp will be the worst case of a frequency divider, but this works pretty well for BW of high speed buffers.....
2. slow nmos and fast pmos or slow pmos and fast nmos  will be the worst case for offset...
Raj.
