Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 10:13pm
Home
Help
Search
Login
Register
PM to admin
Design Languages
Verilog-AMS
› need solution for following error in rtl synthesis tool in cadence
Previous topic
Next topic
need solution for following error in rtl synthesis tool in cadence (Read 1847 times)
aathi27
Mar 06
th
, 2013, 1:49am
reg [7:0]cb[3:0][3:0];
Error : Verilog-2001 feature. [VLOGPT-3] [read_hdl]
: Multiple dimensions in file './sad.v' on line 8, column 22.
: The design must be read in with 'read_hdl -v2001'.
IP Logged
Re: need solution for following error in rtl synthesis tool in cadence
Reply #1 -
Mar 6
th
, 2013, 5:17am
Did you read the error message? It says you have to specify -v2001 because you're using a feature that is from a later version of the language than your simulator supports by default.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
»» Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
