May 3rd, 2024, 2:15am
Precursor ISI cancellation (Read 8148 times)
raja.cedt
Mar 16th, 2013, 7:49am
Hello everyone,
Can any one tell me is Linear Equalizer(CTLE) in RX side can cancel pre-cursor?? I have seen mixed answers in the web saying both yes and no.
http://www.ieee802.org/3/100GNGOPTX/public/jan12/szczepanek_02_0112_NG100GOPTX.p...  slide9
http://www.altera.com/literature/wp/wp-01130-stxv-transceiver.pdf    10th page ctle introduction 3rd line
Raj.
Re: Precursor ISI cancellation
Reply #1 - Apr 2nd, 2013, 3:28am
Hi Raj,
I don't know why it is said that CTLE cannot equalize precursor ISI in INPHI slides. Probably in their specific project, that CTLE is not enough. Anyway, I think it does equalize precursor ISI because a high-pass filter makes the the rising edge more charp in time domain.
And in slide 14 of the link below
http://www.ece.tamu.edu/~spalermo/ecen689/lecture8_ee720_rxeq.pdf,
the 6Gb/s input opens eye with a CTLE. Obviously it equalize precursor ISI because the edge of input data becomes more sharp, otherwise the eye is closed.
Yawei
bharat
Reply #2 - Mar 23rd, 2015, 6:21am
why is post cursor ISI is always more than pre cursor ISI?
or
why the dispersion of impulse response of the channel is not equal on both sides.
The PCIGen3 specifications for Pre-shoot is 6dB and De-emphasis is 9.5dB, means post cursor correction is more than pre cursor correction.
Bharat
BackerShu
Reply #3 - Apr 8th, 2015, 7:46am
@bharat, Interesting question about why there is usually more postcursor than precursor.
First of all, I think mathematically it is always possible to come up a channel which has more precursor. But for a physical cable, I guess one qualitative explanation can be as following:
There are two main loss mechanism in a cable channel: skin effect and dielectric loss. The first one causes only post cursor and the second one causes almost symmetric precursor and post cursor. The overall loss is convolution of the two losses. Therefore, qualitatively, more postcursor exists in physical cable.
A good explanation about these two loss mechanism is covered in this paper:
http://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=1610643
Of course, this explanation is still hand-waving. Hope some expert can give more intuitive answer.
