Jul 17th, 2024, 11:20am
Opamp input common mode voltage (Read 641 times)
neuro11
Mar 17th, 2013, 8:23pm
I am little confused about Opamp input common mode voltage. what i learned from a tutorial is this.
VICM = [VIN (+) + VIN (–)]/2
and
VICMR = VICMR_MAX – VICMR_MIN
Where:
VICMR_MIN = limit relative to VCC – supply rail
VICMR_MAX = limit relative to VCC+ supply rail
But thats not clear to me. Can someone explain the two parameters with some values.
Thanks in advance.
raja.cedt
Re: Opamp input common mode voltage
Reply #1 - Mar 18th, 2013, 12:43am
hello,
you are confused with two.
Vicm gives common mode when you signals applied. It is nothing to do with opamp architecture.
Vicmr_max means how max common mode you can apply to opamp and vicmr_min means how min common mode you can.
Always applied input common mode must fall in the range of vicmr_max-vicmr_min.
There is slight modification between the terms in your post and my reply, but you better follow this. Please have a look on Razavi book.
Raj.
neuro11
Reply #2 - Mar 18th, 2013, 1:39am
hi Raj,
thanks for nthe clarification. I can understand now.
