Jul 15th, 2024, 11:34pm
Architecture name through hierarchy (Read 168 times)
Basil1402
Mar 29th, 2013, 9:06am
Hello all.
I'm having trouble with my implementation.
Here is what I am trying to do :
- I have a testbench file, in which I instanciate a top module.
- In this top module, I instanciate a couple of smaller modules, including one containing many different architectures.
I want to chose the implemented architecture thanks to an argument specified in the testbench file.
What I tried :
- in the testbench file, declaring a string matching one of the architecture and sending it to the top module as a generic.
- in the top module, I created a generic string (say arch_name) and used it to instanciate my smaller module.
With some extremely simplified code :
-- test bench --
ARCHTECTURE beh OF tb_top is
system : ENTITY top(beh)
    GENERIC MAP("arch_name") -- arch_name is a real architecture name of module
-- top --
ENTITY top IS
    GENERIC(example : string)
ARCHITECTURE beh OF top IS
module_1 : ENTITY module(example)
The "vacom" command works fine, but when I try "vasim", it cannot build my system, and Questa tells me that the architectureexample of module does not exist. And it is correct : it is the architecture arch_name I want to use. But it seems it cannot go all the way through the hierarchy.
Do you know :
1- if it is doable ?
2- what the syntax is ?
Thank you in advance.
Basil1402
jerome_ams
Re: Architecture name through hierarchy
Reply #1 - Aug 20th, 2013, 7:29am
The usual way to deal with such a thing is to use configuration files. In such a file you declare the particular architecture you want to bind for your particular setup.
Hope it helps
Cheers
Jerome
