raja.cedt
hello, Most likely systems with high gain will have a tendency to oscillate due to parasitic coupling for instance power amplifier power may coupled through substrate or bond wire inductance to LNA input this may create oscillations. In few cases lower gain may oscillate, so you have to check K-factor.
Thanks, Raj.
