Aug 18th, 2024, 2:25pm
feedback topolgy (Read 3877 times)
aman gupta
India
feedback topolgy
Apr 11th, 2013, 9:49am
What is the feedback topology in the given circuit ??
At the input i can see that input and feedback currents are mixing, but what quantity is being sampled at the output here.
Is it voltage  because i am getting  If = -Vo / Rf
or is it current because    i am also getting  Io= -If......... ??
pls help i am confused
raja.cedt
Re: feedback topolgy
Reply #1 - Apr 11th, 2013, 12:08pm
@ o/p voltage sampling and @ input current mixing. Feedback current depends on the o/p voltage rather o/p voltage as matter of fact i donno how to define o/p current.
Raj.
Vladislav D
The Netherlands
Reply #2 - Apr 11th, 2013, 1:20pm
Nothing is mixing. If case of an ideal amplifier, source current equal exactly to feedback current. Since voltage at the inverting input is a virtual ground, it is equal to DC, whatever current your apply to it i.e input impedance is zero. Consequently, input for this configuration should be a current. Voltage does not make sense, since it would be similar to connecting voltage source to ground.
Output of the amplifier is the only way for current to flow. So output voltage is defined by Rf and input current. If you apply a current source to the output you will see that this does not affect the output voltage. Therefore the output impedance is zero, i.e there is a voltage at the output.
So, this is a current input- voltage output amplifier.
aman gupta
India
Reply #3 - Apr 12th, 2013, 3:11am
tell me what kind of feedback is there in the new figure ?
raja.cedt
Reply #4 - Apr 12th, 2013, 3:31am
voltage sampling at the o/p and voltage mixing at the i/p.
please have a look into razavi basic micro-electronics.
Raj.
buddypoor
Bremen, Germany
Reply #5 - Apr 25th, 2013, 6:34am
aman gupta wrote on Apr 12th, 2013, 3:11am:
It is "current-controlled voltage feedback".
(A clear indication of the fact that the BJT is a voltage-controlled device).
Reply #6 - Apr 26th, 2013, 10:23am
time to buy a few textbooks!
