Aug 18th, 2024, 10:23pm
controlling the frequency of oscialtor (Read 3333 times)
neuro11
May 02nd, 2013, 11:48pm
Hi, is there a oscilator type, the frequency of which can be controlled using one component(capacitor). I mean unlike wien bridge oscilator where RC network determines the condition of oscilation and frequency of oscilaion, i want a oscilator of which frequency can be controlled by a capacitor indepoendent of conditions for oscilations.
Please help!!!
Thnx
raja.cedt
Re: controlling the frequency of oscialtor
Reply #1 - May 3rd, 2013, 12:18am
read about VCO....
neuro11
Reply #2 - May 3rd, 2013, 4:07am
raja.cedt wrote on May 3rd, 2013, 12:18am:
read about VCO....
Hi, thanks for your reply. I will check VCO.
Could you please look at the schematic i attached. I have designed it based on a paper where the author explained the ic model, compnent value every thing and claimed the oscilation can be controlled through C2 only (from 10p to 1n) and oscilation condition depend on C1/C4= R2/R4. But somehow i cant make it work.
Please have a look if i am missing something.
raja.cedt
Reply #3 - May 3rd, 2013, 5:12am
hello,
what kind of oscillator this? but there is some problem at opamp input pin number 3, there is no bias so it will not work.
neuro11
Reply #4 - May 3rd, 2013, 7:55am
raja.cedt wrote on May 3rd, 2013, 5:12am:
hello,
Sorry i have corrected it.
raja.cedt
Reply #5 - May 3rd, 2013, 8:31am
Please have a look on wien bridge osc in  google, you should have an -ve feedback around the op amp through some potential divider....
Raj.
