Jul 17th, 2024, 2:30pm
qpnoise/qpac never starts after successful qpss (Read 2865 times)
Ruiyan
May 03rd, 2013, 2:23am
Hi Guys,
Just wondering what's happening here.
I'm trying to simulate a down conversion receiver with a blocker tone using qpss.
The qpss ran successfully. I'm expecting the qpac or qpnoise to follow that shortly.
However qpac/qpnoise will just sit there, never started even the first frequency point. no warning messages, no errors. I get the initial title for qnoise analysis and the Input Frequency Range = (...). but nothing after that!
Is this likely to be a memory problem?
I did get warnings of intensive swap activity and possible reduced performance.
Thanks.
Ruiyan
RFICDUDE
Re: qpnoise/qpac never starts after successful qpss
Reply #1 - May 5th, 2013, 4:37am
It is probably a memory problem.
If you have a terminal window open you can use the "top" linux command to see processes running. Use the "m" key to display processes according to memory usage. You will probably see the spectre process using most of the physical memory.
If it is a memory problem then you could try using the "swapfile" option for the QPSS/QPAC simulation. This will store information in a swapfile that is not needed for the current calculation. It doesn't slow down the simulation and it will free up memory for the simulator.
Ruiyan
Reply #2 - May 7th, 2013, 2:40am
Many thanks, RFICDUDE. I will try the swapfile option.
