carlgrace wrote on May 7th, 2013, 2:14pm:You're going to have to revisit and re-specify each block.
First, figure out what is limiting your speed to 50 MS/s? Is it the clock generator, settling in the MDAC? The speed of your comparator? Until you can answer that question it is hard to give suggestions!
Also, depending on your process you have to ask yourself if 100 MS/s is do-able.
thanks alot,
I have designed 50MS/s ADC in umc130nm so i thing process is not going to make any problem.
My Comparator, clock generator and Sub-ADC is working upto 250MHz. so i thing that is not a problem.
Only MDAC is hurdle, Should i redesign OTA?
or i change Cs and Cf.
and also upto 100MS/s, what is the best way take references for MDAC and Sub-ADC. it is through internal Bandgap or taking external with huge bypass capacitor outside the chip?
amitesh
