Jul 16th, 2024, 11:25pm
On chip balun for single ended to diff (Read 2594 times)
mixed_signal
May 11th, 2013, 12:14pm
I am using a balun to convert single ended signal (from signal generator) to differential (onchip).
1. Is it necessary to ground the center tap of secondary? I am AC coupling the differential.
2. Since sig gen has 50 ohm impedance i have put a  50 ohm in parallel with primary.
raja.cedt
Re: On chip balun for single ended to diff
Reply #1 - May 12th, 2013, 3:21am
hello,
1.You could connect center tap to any potential as you are using ac coupling, it doesn't matter what you connect.
2.It depends on your Requirement, are you interested in max power TF or maximum voltage TF. If you are interested in narrow band frequency of operation use a matching network between balun and SG.
Raj.
mixed_signal
Reply #2 - May 12th, 2013, 2:20pm
1. Can I leave the center tap unconnected?  Has it any fabrication issues?
The common mode can have any value since it is floating..right?
2. Is it not sufficient to terminate the primary with 50 ohm shunt. I just want my V+ and V- to be +-400mV for testing my subsequent blocks
