raja.cedt
hello, 1.You could connect center tap to any potential as you are using ac coupling, it doesn't matter what you connect. 2.It depends on your Requirement, are you interested in max power TF or maximum voltage TF. If you are interested in narrow band frequency of operation use a matching network between balun and SG.
Thanks, Raj.
