Aug 19th, 2024, 12:20pm
feedback amplifier (Read 6105 times)
aman gupta
India
feedback amplifier
May 17th, 2013, 11:44am
I have to find the feedback polarity. I proceeded as follows :
1. As Iin = iF , increasing Iin will increase iF
2. Now drain current for MF is increasing so Vgs of the transistor should increase
3. That means increasing Iin increase Vout
4. Now as Vout increases the current through RD2 decreases
and all current through RD2 will flow through M2 , this means drain current through M2 is decreasing
5. This will cause gate voltage of M2 to decrease, this will cause current through RD1 to increase which means drain current through M1 increasing which further implies that gate of M1 or drain of MF increasing
Now in short i found that increasing Iin will cause drain voltage of MF to increase
Now my question is how to proceed further    ???
raja.cedt
Re: feedback amplifier
Reply #1 - May 17th, 2013, 1:31pm
hello,
Please don't assume Iin=If which is the final job of the loop, so don't assume this. Let us assume zero input current and zero input voltage.
Now increase gate of M2, drain of M2 decreases,Mf drain increases hence Drain of M1 decreases so -ve feedback.
Raj.
aman gupta
India
Reply #2 - May 17th, 2013, 9:52pm
Can you tell me if Iin increases then why gate voltage for M1 rises ??
raja.cedt
Reply #3 - May 18th, 2013, 12:14pm
1. General way: Whenever some current pumped into a node, potential increases and if current pulled out of node potential decreases(For any stable network).
2. Intuitive way: If you increase Iin some how finally loop should increase current through Mf means Vout should increase, hence M2 gate should decrease so finally M1 gate potential should increase.
Btw did you refer razavi basic micro-electronics text book, i guess he described this kind of problems very clearly...
Good night,
Raj.
aman gupta
India
Reply #4 - May 18th, 2013, 9:39pm
raja.cedt wrote on May 18th, 2013, 12:14pm:
Good night,
Raj.
Thanks a lot .........  Now i got it
yes i am reading that book.........  but i didn't try to apply the intuitive way  :-[
aman gupta
India
Reply #5 - May 18th, 2013, 10:42pm
raja i have 1 doubt
by looking intuitively if we see that as iF increases then gate of MF increases. Now MF is in common source config , so drain of MF should decrease  i think . Wat do you say ??
or even if we assume Vout to be constant initially then increase in iF will also cause decrease in drain voltage in common source.
And the thing you told by analysing the effect of Vout on drain of MF through M1 and M2 is the feedback ( which is negative here) effect i think.....   pls correct me if i am wrong..........
raja.cedt
Reply #6 - May 19th, 2013, 12:48am
yes. Please read my previous post which also saying exactly same.
Reply #7 - May 19th, 2013, 3:19am
Hi aman,
If the load of the MF is a resistor/transistor, the drain voltage of MF decreases as its gate voltage increases because it sinks more current. In that case, the relationship of gate voltage and drain voltage depends on the I/V curve of both the common source amplifier and its load, eg. an resistor load.
But if Iin increases, the drain voltage increases if the gate voltage is not changing, I mean assuming there is not feedback. And the drain voltage increases a lot because that is a high impedance node. Now the negative feedback makes the gate voltage of MF increases so that the drain voltage would not increases so much.
Yawei
aman gupta
India
Reply #8 - May 19th, 2013, 11:08am
ywguo wrote on May 19th, 2013, 3:19am:
Hi aman,
Yawei
Is it a high impedance node because gate of M1 does not sink current ???  if yes then if the current has some other path through MF then why we still call it high impedance node ??
raja.cedt
Reply #9 - May 19th, 2013, 2:30pm
low impedance node ~1/(Gmf1*Gm1*Gm2*R1*R2).
Imagine Mf is a diode connected transistor with high gain in the feedback path
