Jul 17th, 2024, 10:31pm
Veriloga coding of fully differential opamp (Read 12863 times)
fuzail
May 30th, 2013, 7:47am
Iam working on macromodeling of sigma delta adc for this i require veriloga model of fully differential opamp (non-ideal) . Its not that iam asking some one to provide me the code.I have written the code with certain specifications (gain=63db,dominant pole at 172khz) but i don't know how to check the correctness of the code(testbench).I want to know if the code i wrote works as desired(i.e., on simulation it gives same gain and dominant pole freq).
The ieee paper that followed to develop this veriloga model can be found in attachment(veriloga code is written for the ckt diagram in the paper) also iam uploading the code i wrote so that you can find mistakes if any.
To the moderator : This is my first post on DG had i voilated any rules by posting anything that i shouldn't have pls remove it and let me know about the same.
Thanks--
Fuzail.
VerilogA code of fully differntial opamp :
`include "discipline.h"
`include "constants.h"
// model opamp -  Non Ideal OpAmp Model
module opamp (voutp,voutn, vin_p, vin_n, vspply_p, vspply_n, vcm  );
 input  vin_p , vin_n , vcm;
 inout  vspply_p, vspply_n;
 output voutp,voutn ;
 electrical vin_p, vin_n, voutp, voutn, vspply_p, vspply_n, vcm;
  parameter real         gain = 1412.5 exclude 0.0;
  parameter real         pole_freq = 172k;
  parameter real         rin = 12.0M exclude 0.0;
  parameter real         rout = 75.0;
  parameter real         ibias = 0.0n;
  parameter real         vin_offset = 0.0u;
//   parameter real        slewp = 20.0M from (0:inf);
//   parameter real        slewn = -20.0M from (-inf:0);
  real c1, r1;
  real r_rout,gm_nom, vin_val;
  electrical coutp, coutn, vref;
   analog
   begin
      @(initial_step)// or initial_step("dc", "ac", "tran", "xf"))
       begin
                gm_nom = 1.0;
            r1 = gain/gm_nom;
                c1 = gm_nom/(`M_TWO_PI * pole_freq * gain);
                r_rout = rout;
      vin_val=  V(vin_p, vin_n) + vin_offset;
     // ------ Vref  is at Virtual Ground
     V(vref,vspply_n) <+ 0.5*V(vspply_p,vspply_n);
     // ------ Input Stage
      I(vin_p, vin_n) <+ vin_val / rin;
      I(vref, vin_p)  <+ ibias;
      I(vref, vin_n)  <+ ibias;
     // ------ GM stage
     I(vcm, coutp) <+ (gm_nom/2)*vin_val ;
     I(vcm, coutn) <+ -(gm_nom/2)*vin_val ;
     // ------ Dominant Pole.
     I(coutp, vcm) <+c1*ddt(V(coutp, vcm));
     I(coutp, vcm) <+ V(coutp, vcm)/r1;
     I(coutn,vcm) <+ c1*ddt(V(coutn, vcm));
     I(coutn, vcm) <+ V(coutn, vcm)/r1;
     // ------ Output Stage.
     I(vcm, voutp) <+ (V(coutp) - (vcm))/r_rout;
     I(voutp, vcm) <+ V(voutp, vcm)/r_rout;
     I(vcm, voutn) <+ (V(coutn) - V(vcm))/r_rout;
     I(voutn, vcm) <+ V(voutn, vcm)/r_rout;
Couldn't upload ieee paper as the file is large the link is http://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=4746344 however iam uploading the fig with which i developed veriloga code
raja.cedt
Re: Veriloga coding of fully differential opamp
Reply #1 - May 30th, 2013, 11:12am
Why can't you try with ideal components from analog Lib, i guess it is much more easier than verilogA. Try with Voltage Controlled Voltage Sourse
fuzail
Reply #2 - May 31st, 2013, 1:58am
Hi raja,
First thanks for replying. My main question was how to check if the code works.....? the test bench..? be it code/schematic test bench would be required to check if ur ckt/code is working/not.
And in my project use of veriloga is necessary so i can't go by the electrical equivalent(ckt) of the code.
ali_kourani
Reply #3 - Jun 3rd, 2013, 3:10am
hello , I used the ahdlLib code and transfer it to differential o/p, and it is very similar to ur code , however when I apply it for a real amplifier (input caps and output caps), the transient is not differential anymore
can u help me
the test bench is attached here with the o/p transient of amplifier
ali_kourani
Reply #4 - Jun 3rd, 2013, 3:12am
here is the o/p transient
