Sep 6th, 2024, 1:19am
Total error of a bandgap in mc (Read 1526 times)
melinda
Romania
Jun 10th, 2013, 12:15am
I want to calculate the total error of a bandgap reference . I think the error of a reference are given by  the error of Vbe, the error of deltaVbe, the error af an opamp (offset) and the error of the resistive ratio.
Please can anyone tell me if there are others error and if the total error is equal to the geometric mean of all the errors ?
Horror Vacui
Dresden, Germany
Re: Total error of a bandgap in mc
Reply #1 - Jun 11th, 2013, 2:10am
Yes, these are error sources. I think you listed all parts of the bandgap circuit Smiley
The general procedure to obtain the mismatch is to
1. derive the formula for your output parameter, and then
2. differentiate it for all parameters which are not constant.
3. Add the error values (for example dR/R=1%) --> to get stdev for every error ource
4. Sum the square of the standard deviations if the error sources uncorrelated to obtain the square of the standard deviation of the whole circuit
