Sep 20th, 2026, 3:56am
mtline spectre connection (Read 10877 times)
hpvlsi
Jun 12th, 2013, 9:43am
When using mtline model in cadence spectre schematic simulation, why I can not connect output of one mtline to output of another mtline? (warnings show there will be short circuit and floating nodes)
Re: mtline spectre connection
Reply #1 - Jul 8th, 2013, 5:37am
hpvlsi,
  You are getting a warning because you are shorting two outputs.
Tested the case of two mtlines outputs shorted and the simulation
seems to run. Does your circuit simulate?
Frank Wiedmann
Munich, Germany
Reply #2 - Jul 8th, 2013, 5:58am
This question has been answered at http://www.cadence.com/community/forums/T/26497.aspx.
hpvlsi
Reply #3 - Jul 20th, 2013, 10:36am
the simulation result is fine, I just do not like the warnings, and http://www.cadence.com/community/forums/T/26497.aspx solves it.
Thanks.
sheldon wrote on Jul 8th, 2013, 5:37am:
hpvlsi,
hpvlsi
Reply #4 - Jul 20th, 2013, 10:36am
Thanks! That is exactly what I need
Frank Wiedmann wrote on Jul 8th, 2013, 5:58am:
