hpvlsi
Hi, the simulation result is fine, I just do not like the warnings, and http://www.cadence.com/community/forums/T/26497.aspx solves it. Thanks. sheldon wrote on Jul 8th, 2013, 6:37am:hpvlsi,
You are getting a warning because you are shorting two outputs. Tested the case of two mtlines outputs shorted and the simulation seems to run. Does your circuit simulate?
