vitto
I am designing a transmitter-receiver system working at 2 MHz. This is not for radio communication, but for environment sensing. There is no bandwidth to worry about and the power is low (<1W). My antennas are small loops (approx. 4 inch) diameter and are each connected to a tiny tx and rx boards respectively.
I was given the schematics of these boards, which are very simple. The transmitter consists of a simple matching network, to match the impedance of the antenna to the 50 ohm feed line and to bring resonance at the desired frequency (2 MHz). The surprise was when I looked at the receiver: there is no matching network whatsoever. The antenna is fed directly into a differential amplifier and that's it. When I asked them why they told me "we tune the transmitter, then the receiver just picks up whatever".
Now they are going to send these boards to production and I am not feeling comfortable with that!
Does anybody have suggestions on how to design a simple matching network to match my receiving antenna to the receiver amplifier? I don't have much experience working in this frequency band (I normally work in the microwave region). Any example circuit that could help get me get started?
Thanks!
