Sep 5th, 2024, 9:18pm
Source follower using an NMOS transistor as current source. (Read 4816 times)
baab
EA
Jun 18th, 2013, 4:09pm
Hello!
Today, I got stuck with this circuit: Source follower using an NMOS transistor as current source.
I want to know what calculation you would do to use the circuit in real world.
What value of I1 do I need?
I think I can choose any value, no problem!
What is the value of Vb?
From the saturation mode, I can figure out Vb.
How do you choose Vin to make M2 operates in saturation mode?
(M1 is always in saturation mode)
I want to know how you would choose Vin to operate.
For me the first thing is to analyse large signal model then choose an operating point.
Can you comment on my method?
Thanks.
saket
Re: Source follower using an NMOS transistor as current source.
Reply #1 - Jun 19th, 2013, 11:10am
Vin needs to be at least VDSAT, M2 + VGS, M1 higher than ground level.
The situation is a little complicated if there is back-gate biasing on M1. That is, its source and substrate are at different potentials. This will make the threshold voltage vary with the output.
You will have to make sure that Vin-(VDSAT, M2+VGS,M1) is is always greater than zero across corners.
